<html>
<head><title>404 Not Found</title></head>
<body>
<center><h1>404 Not Found</h1></center>
<hr><center>nginx</center>
</body>
</html>/* Js for , Version=1791638980 */
(function(){
    var bp = document.createElement('script');
    var curProtocol = window.location.protocol.split(':')[0];
    if (curProtocol === 'https') {
        bp.src = 'https://zz.bdstatic.com/linksubmit/push.js';
    else {
        bp.src = 'http://push.zhanzhang.baidu.com/push.js';
    var s = document.getElementsByTagName("script")[0];
    s.parentNode.insertBefore(bp, s);
var _hmt = _hmt || [];
(function() {
  var hm = document.createElement("script");
  hm.src = "https://hm.baidu.com/hm.js?66783adfbe42420ef9c6b0aeddb79456";
  s.parentNode.insertBefore(hm, s);
;(function() {var _53code = document.createElement("script");_53code.src = "https://tb.53kf.com/code/code/518e83c5598807c0c519117111c00c0d1/1";var s = document.getElementsByTagName("script")[0]; s.parentNode.insertBefore(_53code, s);})();;
(function() {
  hm.src = "https://hm.baidu.com/hm.js?cd1a29694ca3a3d80a887a92493664cb";
;var config={"webRoot":"\/","cookieLife":30,"cookiePath":"\/","requestType":"PATH_INFO","requestFix":"-","moduleVar":"m","methodVar":"f","viewVar":"t","defaultView":"html","themeRoot":"\/theme\/","currentModule":"index","currentMethod":"index","clientLang":"zh-cn","requiredFields":"","save":"\u4fdd\u5b58","router":"\/index.php","runMode":"front","langCode":""}
;if(typeof(v) != "object") v = {};v.theme = {"template":"default","theme":"wide","device":"desktop"};;v.lang = {"confirmDelete":"\u60a8\u786e\u5b9a\u8981\u6267\u884c\u5220\u9664\u64cd\u4f5c\u5417\uff1f","deleteing":"\u5220\u9664\u4e2d","doing":"\u5904\u7406\u4e2d","loading":"\u52a0\u8f7d\u4e2d","updating":"\u66f4\u65b0\u4e2d...","timeout":"\u7f51\u7edc\u8d85\u65f6,\u8bf7\u91cd\u8bd5","errorThrown":"<h4>\u6267\u884c\u51fa\u9519\uff1a<\/h4>","continueShopping":"\u7ee7\u7eed\u8d2d\u7269","required":"\u5fc5\u586b","back":"\u8fd4\u56de","continue":"\u7ee7\u7eed","bindWechatTip":"\u53d1\u5e16\u529f\u80fd\u8bbe\u7f6e\u4e86\u7ed1\u5b9a\u5fae\u4fe1\u7684\u9650\u5236\uff0c\u8bf7\u5148\u7ed1\u5b9a\u5fae\u4fe1\u4f1a\u5458\u3002","importTip":"\u53ea\u5bfc\u5165\u4e3b\u9898\u7684\u98ce\u683c\u548c\u6837\u5f0f","fullImportTip":"\u5c06\u4f1a\u5bfc\u5165\u6d4b\u8bd5\u6570\u636e\u4ee5\u53ca\u66ff\u6362\u7ad9\u70b9\u6587\u7ae0\u3001\u4ea7\u54c1\u7b49\u6570\u636e"};;
	jQuery(function($){
		//内似于tab切换，在导航父元素加parents，在每个子元素加child
		var _toggleIndex='';
		$('.index-product .parents li').hover(function(){
		    $(this).addClass('active').siblings().removeClass('active')
		    var index=$(this).index()
		    if(index == _toggleIndex)return;
		    _toggleIndex=index;
		    var childDom=$(this).parents('.toggle').find('.child').get(index)
		    $(childDom).addClass('active').siblings().removeClass('active')
		    if($('.type-item ').length>1){
		        indexSwiper('.type-item ')
		//导航栏中的menu
		var _menuIndex='';
		$('.menu-product dd').hover(function(){
		    if(index == _menuIndex)return;
		    _menuIndex=index;
		    var childDom=$('.all-panel').get(index)
;$(document).ready(function()
    // add "index" class to the body element.
    $('body').addClass('index');
    $('.nav-system-home:first').addClass('active');
/*$('input').bind('click','focus',function(){
  $('select').css('display','block')
  $('select').attr('multiple','multiple')
$('option').click(function(e){
    $('select').css('display','none')
    $('input').prop('value',e.target.label)
$('input').on('input',function(){
$("a").attr("target","_self");
$("a.compare").attr("target","");
// $(".product-nav a").attr("target","_self");
$('a.out-link').attr("target","_blank");$("#block272").insertBefore("#infor1");
$("#block273").insertBefore("#infor2");
$("#block274").insertBefore("#infor3");
$("#block266").insertBefore("#inforT1");
$("#block267").insertBefore("#inforT2");
$("#block283").insertBefore("#inforT3");
jQuery(function($){
    // 加载动画
	if (!(/msie [6|7|8|9]/i.test(navigator.userAgent))){
		var wow = new WOW({
			boxClass: 'wow',
			animateClass: 'animated',
			offset: -50,
			mobile: true,
			live: true
		wow.init();
	$('#header').mouseover(function(){
	    $(this).addClass('header-fixed');
	}).mouseout(function(){
	    $(this).removeClass('header-fixed');
    $(window).bind("scroll",function(){
        let topScroll=$(this).scrollTop();//当前窗口的滚动距离
        if(topScroll > 0){
        	$("#header").addClass("header-fixed");
        }else{
        	$("#header").removeClass("header-fixed")
var hash = window.location.hash.substring(1);
var browserLanguage = navigator.language || navigator.userLanguage;
var resolution      = screen.availWidth + ' X ' + screen.availHeight;
$.get(createLink('log', 'record', "hash=" + hash), {browserLanguage:browserLanguage, resolution:resolution});
    $(function(){
        //判断手机端
        if(/Android|webOS|iPhone|iPod|BlackBerry/i.test(navigator.userAgent)) {
            $("ul.page").hide();
            $("aside").css({"bottom":"50px","top":"initial"});
            //$(".list_new:not(:last-child)").remove();
            $(".list_new.phone-hide").remove();
            $('.list_new:first-child').css('border-radius','10px');
            $('.list_new_left').remove();
        } else {
            $(".pager.form-inline").hide();
        //返回顶部按钮
        var backButton = $("#scrolltop");
        var height = backButton.offset().top;
        // 滑动滚动条
        function backToTop() {
            $('html,body').animate({
                scrollTop: 0
            }, 800);
        backButton.on('click', backToTop);
