/* Js for , Version=1792412434 */
(function(){
    var bp = document.createElement('script');
    var curProtocol = window.location.protocol.split(':')[0];
    if (curProtocol === 'https') {
        bp.src = 'https://zz.bdstatic.com/linksubmit/push.js';
    else {
        bp.src = 'http://push.zhanzhang.baidu.com/push.js';
    var s = document.getElementsByTagName("script")[0];
    s.parentNode.insertBefore(bp, s);
var _hmt = _hmt || [];
(function() {
  var hm = document.createElement("script");
  hm.src = "https://hm.baidu.com/hm.js?66783adfbe42420ef9c6b0aeddb79456";
  s.parentNode.insertBefore(hm, s);
;(function() {var _53code = document.createElement("script");_53code.src = "https://tb.53kf.com/code/code/518e83c5598807c0c519117111c00c0d1/1";var s = document.getElementsByTagName("script")[0]; s.parentNode.insertBefore(_53code, s);})();;
(function() {
  hm.src = "https://hm.baidu.com/hm.js?cd1a29694ca3a3d80a887a92493664cb";
;var config={"webRoot":"\/","cookieLife":30,"cookiePath":"\/","requestType":"PATH_INFO","requestFix":"-","moduleVar":"m","methodVar":"f","viewVar":"t","defaultView":"mhtml","themeRoot":"\/theme\/","currentModule":"article","currentMethod":"view","clientLang":"zh-cn","requiredFields":"","save":"\u4fdd\u5b58","router":"\/index.php","runMode":"front","langCode":""}
;if(typeof(v) != "object") v = {};v.theme = {"template":"default","theme":"wide","device":"desktop"};;v.lang = {"confirmDelete":"\u60a8\u786e\u5b9a\u8981\u6267\u884c\u5220\u9664\u64cd\u4f5c\u5417\uff1f","deleteing":"\u5220\u9664\u4e2d","doing":"\u5904\u7406\u4e2d","loading":"\u52a0\u8f7d\u4e2d","updating":"\u66f4\u65b0\u4e2d...","timeout":"\u7f51\u7edc\u8d85\u65f6,\u8bf7\u91cd\u8bd5","errorThrown":"<h4>\u6267\u884c\u51fa\u9519\uff1a<\/h4>","continueShopping":"\u7ee7\u7eed\u8d2d\u7269","required":"\u5fc5\u586b","back":"\u8fd4\u56de","continue":"\u7ee7\u7eed","bindWechatTip":"\u53d1\u5e16\u529f\u80fd\u8bbe\u7f6e\u4e86\u7ed1\u5b9a\u5fae\u4fe1\u7684\u9650\u5236\uff0c\u8bf7\u5148\u7ed1\u5b9a\u5fae\u4fe1\u4f1a\u5458\u3002","importTip":"\u53ea\u5bfc\u5165\u4e3b\u9898\u7684\u98ce\u683c\u548c\u6837\u5f0f","fullImportTip":"\u5c06\u4f1a\u5bfc\u5165\u6d4b\u8bd5\u6570\u636e\u4ee5\u53ca\u66ff\u6362\u7ad9\u70b9\u6587\u7ae0\u3001\u4ea7\u54c1\u7b49\u6570\u636e"};;v.path = ["13","14"];;v.objectType = "article";;v.objectID = 828;;v.categoryID = 14;;v.categoryPath = ["13","14"];;<script>
function switchTab(el) {
  // 获取当前点击 tab 的索引
  var idx = parseInt(el.getAttribute('data-index'), 10);
  // 获取所有 tab 项和所有面板
  var tabs = document.querySelectorAll('#fxTabList .fx-tab-item');
  var panels = document.querySelectorAll('#fxTabPanels .fx-tab-panel');
  // 先全部移除 active 状态
  for (var i = 0; i < tabs.length; i++) {
    tabs[i].classList.remove('fx-active');
    panels[i].classList.remove('fx-active');
  // 为当前选中的 tab 和对应面板添加 active
  tabs[idx].classList.add('fx-active');
  panels[idx].classList.add('fx-active');
;v.pageLayout = "global";;$(document).ready(function()
    $('#copyBox').hide().find(':input').attr('disabled', true);
    $('#source').change(function()
        if($(this).val() != 'original') $('#copyBox').show().find(':input').attr('disabled', false);
    /* Set current active topNav. */
    var hasActive = false;
    if(v.categoryID > 0 && $('.nav-article-' + v.categoryID).length >= 1)
        hasActive = true;
        $('.nav-article-' + v.categoryID).addClass('active');
    if(v.categoryPath && v.categoryPath.length)
        $.each(v.categoryPath, function(index, category)
            if(!hasActive)
                if($('.nav-article-' + category).length >= 1) hasActive = true;
                $('.nav-article-' + category).addClass('active');
    else if(v.path && v.path.length)
        $.each(v.path, function(index, category)
            if(!hasActive)
        if(!hasActive) $('.nav-article-0').addClass('active');
    if(v.categoryID !== 0) $('#category' + v.categoryID).parent().addClass('active');
    function basename(str)
        var pos = str.lastIndexOf('/');
        return str.substring(pos + 1,str.length);
    $('body').tooltip(
        html: true,
        selector: "[data-toggle=tooltip]",
        container: "body"
    $('.article-content img').click(function(){
        var itemSrc  = $(this).attr('src');
        var itemName = basename(itemSrc).split('.')[0];
        if(typeof(itemName) == 'string')
            $('.article-files .' + itemName).click();
    if($('.previous > a > span').width() > $('.previous > a').width())
        previousSpanWidth = $('.previous > a').width() - $('.previous .icon-arrow-left').width() - 5;
        $('.previous > a > span').css('width', previousSpanWidth);
    if($('.next > a > span').width() > $('.next > a').width())
        nextSpanWidth = $('.next > a').width() - $('.next .icon-arrow-right').width() - 5;
        $('.next > a > span').css('width', nextSpanWidth);
/*$('input').bind('click','focus',function(){
  $('select').css('display','block')
  $('select').attr('multiple','multiple')
$('option').click(function(e){
    $('select').css('display','none')
    $('input').prop('value',e.target.label)
$('input').on('input',function(){
$("a").attr("target","_self");
$("a.compare").attr("target","");
// $(".product-nav a").attr("target","_self");
$('a.out-link').attr("target","_blank");
var hash = window.location.hash.substring(1);
var browserLanguage = navigator.language || navigator.userLanguage;
var resolution      = screen.availWidth + ' X ' + screen.availHeight;
$.get(createLink('log', 'record', "hash=" + hash), {browserLanguage:browserLanguage, resolution:resolution});
    $(function(){
        //判断手机端
        if(/Android|webOS|iPhone|iPod|BlackBerry/i.test(navigator.userAgent)) {
            $("ul.page").hide();
            $("aside").css({"bottom":"50px","top":"initial"});
            //$(".list_new:not(:last-child)").remove();
            $(".list_new.phone-hide").remove();
            $('.list_new:first-child').css('border-radius','10px');
            $('.list_new_left').remove();
        } else {
            $(".pager.form-inline").hide();
        //返回顶部按钮
        var backButton = $("#scrolltop");
        var height = backButton.offset().top;
        // 滑动滚动条
        function backToTop() {
            $('html,body').animate({
                scrollTop: 0
            }, 800);
        backButton.on('click', backToTop);
