【飞凌嵌入式 OK3399-C+开发板试用体验】使用多媒体QCamera和QPointer相关类
作者:donatello1996
参考了GitHub上某位大佬的代码,使用QCamera QCameraInfo QCameraImageCapture QPointer QActionGroup这些类来实现USB摄像头图像读取,其中三个QCamera的相关类需要在pro文件中加入** **widgets即多媒体类库支持:
QT += core gui ** **widgets
然后是定义相关指针,我试过直接用*指针来定义不行,必须要用模板类指针:
class MainWindow : public QMainWindow
Q_OBJECT
public:
explicit MainWindow(QWidget *parent = nullptr);
~MainWindow();
private slots:
void refreshCameras();
void refreshFormats();
void refreshResolutions();
void setCamera(QCameraInfo info);
void setFormat(QString format);
void setResolution(QSize resolution);
void disconnectCamera();
void updateImage();
private:
Ui::MainWindow *ui;
QList<QCameraInfo> cameras;
QStringList formats;
QList<QSize> resolutions;
<font color="Blue">QCamera *camera;
QPointer<QCameraImageCapture> capture;</font>
VideoSu**ce su**ce;
QPointer<QActionGroup> ActionGroupCameras;
QPointer<QActionGroup> ActionGroupFormats;
QPointer<QActionGroup> ActionGroupResolutions;
MainWindow::MainWindow(QWidget *parent) :
QMainWindow(parent),
ui(new Ui::MainWindow)
ui->setupUi(this);
thread1 = new mythread(this);
refreshCameras();
connect(&su**ce, &VideoSu**ce::newImageReady, this, &MainWindow::updateImage);
QCamera类对象camera需要跟QCameraInfo类的对象info绑定相关信息,查看QT库定义,只在构造函数中绑定QCameraInfo类,因此每次切换信息都需要使用new的方式绑定,QCameraImageCapture类同理:
void MainWindow::setCamera(QCameraInfo info)
delete camera;
delete capture;
camera = new QCamera(info, this);
capture = new QCameraImageCapture(camera, this);
camera->setViewfinder(&su**ce);
camera->load();
camera->start();
//refreshFormats();
ui->actionDisconnect->setEnabled(true);
void MainWindow::disconnectCamera()
delete camera;
delete capture;
for (QAction *action : ui->menuCameras->actions()) {
action->setChecked(false);
ui->actionDisconnect->setEnabled(false);
void MainWindow::refreshCameras()
disconnectCamera();
cameras = QCameraInfo::availableCameras();
delete ActionGroupCameras;
ActionGroupCameras = new QActionGroup(this);
ui->menuCameras->clear();
if (cameras.size())
ui->menuCameras->setEnabled(true);
for (const QCameraInfo &info: cameras)
QAction *action = new QAction(info.description(), ActionGroupCameras); // capture->imageCodecDescription(codec)
action->setCheckable(true);
ui->menuCameras->addAction(action);
connect(action, &QAction::triggered, [=]()
setCamera(info);
qDebug() << "Opening camera:" << info.deviceName();
qDebug() << "\t- Description:" << info.description();
qDebug() << "\t- Position:" << info.position();
} else
ui->menuCameras->setDisabled(true);
void MainWindow::updateImage()
ui->imageLabel->setPixmap(su**ce.getPixmap().scaledToWidth(ui->imageLabel->width(), Qt::SmoothTransformation));
这些都做好之后就在ui文件中添加下拉菜单即可,有刷新摄像头列表信息,断开连接,读取摄像头信息到列表等功能:
FET3399-C核心板
OK3399-C开发板
