【飞凌嵌入式 OK3399-C+开发板试用体验】使用多媒体QCamera和QPointer相关类
作者:donatello1996
参考了GitHub上某位大佬的代码,使用QCamera QCameraInfo QCameraImageCapture QPointer QActionGroup这些类来实现USB摄像头图像读取,其中三个QCamera的相关类需要在pro文件中加入** **widgets即多媒体类库支持:
QT += core gui ** **widgets
然后是定义相关指针,我试过直接用*指针来定义不行,必须要用模板类指针:
class MainWindow : public QMainWindow { Q_OBJECT public: explicit MainWindow(QWidget *parent = nullptr); ~MainWindow(); private slots: void refreshCameras(); void refreshFormats(); void refreshResolutions(); void setCamera(QCameraInfo info); void setFormat(QString format); void setResolution(QSize resolution); void disconnectCamera(); void updateImage(); private: Ui::MainWindow *ui; QList<QCameraInfo> cameras; QStringList formats; QList<QSize> resolutions; <font color="Blue">QCamera *camera; QPointer<QCameraImageCapture> capture;</font> VideoSu**ce su**ce; QPointer<QActionGroup> ActionGroupCameras; QPointer<QActionGroup> ActionGroupFormats; QPointer<QActionGroup> ActionGroupResolutions; };
MainWindow::MainWindow(QWidget *parent) : QMainWindow(parent), ui(new Ui::MainWindow) { ui->setupUi(this); thread1 = new mythread(this); refreshCameras(); connect(&su**ce, &VideoSu**ce::newImageReady, this, &MainWindow::updateImage); }
QCamera类对象camera需要跟QCameraInfo类的对象info绑定相关信息,查看QT库定义,只在构造函数中绑定QCameraInfo类,因此每次切换信息都需要使用new的方式绑定,QCameraImageCapture类同理:
void MainWindow::setCamera(QCameraInfo info) { delete camera; delete capture; camera = new QCamera(info, this); capture = new QCameraImageCapture(camera, this); camera->setViewfinder(&su**ce); camera->load(); camera->start(); //refreshFormats(); refreshResolutions(); ui->actionDisconnect->setEnabled(true); }
void MainWindow::disconnectCamera() { delete camera; delete capture; for (QAction *action : ui->menuCameras->actions()) { action->setChecked(false); } ui->actionDisconnect->setEnabled(false); }
void MainWindow::refreshCameras() { disconnectCamera(); cameras = QCameraInfo::availableCameras(); delete ActionGroupCameras; ActionGroupCameras = new QActionGroup(this); ui->menuCameras->clear(); if (cameras.size()) { ui->menuCameras->setEnabled(true); for (const QCameraInfo &info: cameras) { QAction *action = new QAction(info.description(), ActionGroupCameras); // capture->imageCodecDescription(codec) action->setCheckable(true); ui->menuCameras->addAction(action); connect(action, &QAction::triggered, [=]() { setCamera(info); }); } for (const QCameraInfo &info: cameras) { qDebug() << "Opening camera:" << info.deviceName(); qDebug() << "\t- Description:" << info.description(); qDebug() << "\t- Position:" << info.position(); } } else { ui->menuCameras->setDisabled(true); } }
void MainWindow::updateImage() { ui->imageLabel->setPixmap(su**ce.getPixmap().scaledToWidth(ui->imageLabel->width(), Qt::SmoothTransformation)); }
这些都做好之后就在ui文件中添加下拉菜单即可,有刷新摄像头列表信息,断开连接,读取摄像头信息到列表等功能:
