[新手指导]imx6开发板 SDHC/SDXC/MMC卡驱动测试
原创 2020-03-07 15:26:00 imx6开发板 imx6 imx6 开发板
以下操作基于飞凌嵌入式imx6开发板
 命令行测试法
imx6开发板支持SD卡热插拔。插上SD卡后系统会自动将其挂载到/media目录。同时终端会打印关于SD卡的信息,由于存在很多种卡,显示的信息可能会有差别:
root@freescale ~$ mmc2: new high speed SDHC card at address aaaa
mmcblk1: mmc2:aaaa SS08G 7.40 GiB
 mmcblk1: p1
mmcblk1: p1 p2
EXT3-fs: barriers not enabled
kjournald starting.  Commit interval 5 seconds
EXT3-fs (mmcblk1p2): using internal journal
EXT3-fs (mmcblk1p2): recovery complete
EXT3-fs (mmcblk1p2): mounted filesystem with writeback data mode
挂载普通8G SD卡
root@freescale /$ ls /media
mmcblk0p1  mmcblk1p1  mmcblk1p2
查看SD卡中的文件,命令如下:
root@freescale /media$ ls -l /media/mmcblk1p1/
drwxr-xr-x    2 root     root          4096 May 22  2015 ??
drwxr-xr-x    2 root     root          4096 Nov 23  2014 LOST.DIR
-rwxr-xr-x    1 root     root         22612 Jan 15  2015 MLO
-rwxr-xr-x    1 root     root          3236 Jan 15  2015 app
drwxr-xr-x    2 root     root          4096 May 15  2015 ok335-s
root@freescale /media$ ls -l /media/mmcblk1p2/
drwxr-sr-x    2 root     root          4096 Sep 22  2013 bin
drwxr-sr-x    2 root     root          4096 Apr  5  2013 dev
drwxr-sr-x   26 root     root          4096 Jan 13  2015 etc
drwxr-sr-x    7 root     root          4096 Jun 16  2014 forlinx
drwxr-sr-x    4 root     root          4096 May 20  2014 home
drwxr-sr-x    8 root     root          4096 May 20  2014 lib
drwxr-sr-x   13 root     root          4096 Jan 13  2015 media
drwxr-sr-x    3 root     root          4096 Apr  5  2013 mnt
drwxr-xr-x    3 root     root          4096 May 21  2014 opt
drwxr-sr-x    2 root     root          4096 Apr  5  2013 proc
drwxr-sr-x    2 root     root          4096 May 20  2014 sbin
drwxr-sr-x    2 root     root          4096 Jan  2  2014 srv
drwxr-sr-x    2 root     root          4096 Apr  5  2013 sys
lrwxrwxrwx    1 root     root             8 Sep 17  2013 tmp -> /var/tmp
drwxr-sr-x    9 root     root          4096 Jan  2  2014 usr
drwxr-sr-x    8 root     root          4096 May 20  2014 var
sdxc卡设置使用格式话成ext2或ext3或ext4
root@freescale /$ mkfs.ext2 /dev/mmcblk1p1
Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
3923968 inodes, 15691520 blocks
784576 blocks (5%) reserved for the super user
First data block=0
Maximum filesystem blocks=16777216
479 block groups
32768 blocks per group, 32768 fragments per group
8192 inodes per group
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424
重启imx6开发板
mmc2: new high speed SDXC card at address 59b4
mmcblk1: mmc2:59b4 SDU1  59.8 GiB
 mmcblk1: p1
root@freescale /media$ cd mmcblk1p1/
root@freescale /media/mmcblk1p1$ ls
lost+found
128G的sdxc卡识别
mmcblk1: mmc2:59b4 SDU1  119 GiB
 mmcblk1: p1
EXT2-fs (mmcblk1p1): warning: mounting unchecked fs, running e2fsck is recommend
Ed
root@freescale ~$ cd /media/
mmcblk0p1  mmcblk1p1
lost+found
备注:目前 imx6开发板 测试支持最大32GiB SDHC卡,最大128GiB SDXC卡(格式化成ext2/3/4使用)。
更多imx6产品详情敬请关注飞凌嵌入式产品中心
  • FETMX6Q-C核心板
    FETMX6Q-C核心板
  • OKMX6Q-C开发板
    OKMX6Q-C开发板
  • FETMX6Q-S核心板
    FETMX6Q-S核心板
  • OKMX6Q-S3开发板
    OKMX6Q-S3开发板
