RK3568 开发板 Buildroot 环境下内核 Logo 动画效果配置实操指南
Forlinx
2026-02-10 16:25:00
RK3568开发板
Logo动画效果
一、准备工作:图片格式转换
需提前准备动画所需的 连续序列图片(建议 25 张,对应动画帧 00-24),并按以下命令转换为内核支持的 ppm 格式:
1.1 PNG格式转换
若图片为 PNG 格式,使用以下命令转换:
pngtopnm logo.png > logo.pnm
1.2 BMP格式转换
若图片为 BMP 格式,使用以下命令转换:
bmptopnm logo.bmp > logo.pnm
1.3 统一转为224色ppm格式
将转换后的图片统一处理为内核支持的224色ppm格式:
pnmquant 224 logo.pnm > logo224.pnm pnmtoplainpnm logo224.pnm > logo_linuxXX_clut224.ppm
XX 需替换为 00-24(对应 25 帧动画,如 logo_linux00_clut224.ppm、logo_linux01_clut224.ppm)。
二、文件部署:拷贝至内核指定目录
将转换后的 25 张logo_linuxXX_clut224.ppm图片,拷贝到内核源码的 logo 驱动目录:
OK3568-linux-source/kernel/drivers/video/logo/
三、配置修改:核心文件编辑
(一)修改 Makefile(编译规则添加)
编辑 Makefile,添加新增图片的编译规则,确保 25 帧图片被内核编译:
OK3568-linux-source/kernel/drivers/video/logo/Makefile
(二)修改 logo.c(帧切换逻辑)
编辑 logo.c,修正语法错误并添加帧序列匹配逻辑:
OK3568-linux-source/kernel/drivers/video/logo/logo.c
diff --git a/drivers/video/logo/logo.c b/drivers/video/logo/logo.c
index 36aa050f9..71ce3bade 100644
--- a/drivers/video/logo/logo.c
+++ b/drivers/video/logo/logo.c
@@ -43,6 +43,8 @@ late_initcall_sync(fb_logo_late_init);
const struct linux_logo *fb_find_logo(int depth)
const struct linux_logo *logo = NULL;
+ int num = depth >> 16;
+ depth &= 0xFFFF;
if (nologo || logos_freed)
return NULL;
@@ -72,7 +74,34 @@ const struct linux_logo *_ref fb_find_logo(int depth)
if (depth >= 8) {
#ifdef CONFIG_LOGO_LINUX_CLUT224
/* Generic Linux Logo */
- logo = &logo_linux_clut224;
+ // logo = &logo_linux_clut224;
+ switch (num) {
+ case 0: logo = &logo_linux00_clut224; break;
+ case 1: logo = &logo_linux01_clut224; break;
+ case 2: logo = &logo_linux02_clut224; break;
+ case 3: logo = &logo_linux03_clut224; break;
+ case 4: logo = &logo_linux04_clut224; break;
+ case 5: logo = &logo_linux05_clut224; break;
+ case 6: logo = &logo_linux06_clut224; break;
+ case 7: logo = &logo_linux07_clut224; break;
+ case 8: logo = &logo_linux08_clut224; break;
+ case 9: logo = &logo_linux09_clut224; break;
+ case 10: logo = &logo_linux10_clut224; break;
+ case 11: logo = &logo_linux11_clut224; break;
+ case 12: logo = &logo_linux12_clut224; break;
+ case 13: logo = &logo_linux13_clut224; break;
+ case 14: logo = &logo_linux14_clut224; break;
+ case 15: logo = &logo_linux15_clut224; break;
+ case 16: logo = &logo_linux16_clut224; break;
+ case 17: logo = &logo_linux17_clut224; break;
+ case 18: logo = &logo_linux18_clut224; break;
+ case 19: logo = &logo_linux19_clut224; break;
+ case 20: logo = &logo_linux20_clut224; break;
+ case 21: logo = &logo_linux21_clut224; break;
+ case 22: logo = &logo_linux22_clut224; break;
+ case 23: logo = &logo_linux23_clut224; break;
+ case 24: logo = &logo_linux24_clut224; break;
#endif
#ifdef CONFIG_LOGO_DEC_CLUT224
/* DEC Linux logo (on MIPS/MIPS64 or ALPHA) */
(三)修改 linux_logo.h(结构体声明)
编辑 linux_logo.h,修正语法错误并声明 25 帧图片结构体:
OK3568-linux-source/kernel/include/linux/linux_logo.h
diff --git a/include/linux/linux_logo.h b/include/linux/linux_logo.h
index d4d5b93ef..b0ffc168b 100644
--- a/include/linux/linux_logo.h
+++ b/include/linux/linux_logo.h
@@ -35,7 +35,32 @@ struct linux_logo {
extern const struct linux_logo logo_linux_mono;
extern const struct linux_logo logo_linux_vga16;
-extern const struct linux_logo logo_linux_clut224;
+// extern const struct linux_logo logo_linux_clut224;
+extern const struct linux_logo logo_linux00_clut224;
+extern const struct linux_logo logo_linux01_clut224;
+extern const struct linux_logo logo_linux02_clut224;
+extern const struct linux_logo logo_linux03_clut224;
+extern const struct linux_logo logo_linux04_clut224;
+extern const struct linux_logo logo_linux05_clut224;
+extern const struct linux_logo logo_linux06_clut224;
+extern const struct linux_logo logo_linux07_clut224;
+extern const struct linux_logo logo_linux08_clut224;
+extern const struct linux_logo logo_linux09_clut224;
+extern const struct linux_logo logo_linux10_clut224;
+extern const struct linux_logo logo_linux11_clut224;
+extern const struct linux_logo logo_linux12_clut224;
+extern const struct linux_logo logo_linux13_clut224;
+extern const struct linux_logo logo_linux14_clut224;
+extern const struct linux_logo logo_linux15_clut224;
+extern const struct linux_logo logo_linux16_clut224;
+extern const struct linux_logo logo_linux17_clut224;
+extern const struct linux_logo logo_linux18_clut224;
+extern const struct linux_logo logo_linux19_clut224;
+extern const struct linux_logo logo_linux20_clut224;
+extern const struct linux_logo logo_linux21_clut224;
+extern const struct linux_logo logo_linux22_clut224;
+extern const struct linux_logo logo_linux23_clut224;
+extern const struct linux_logo logo_linux24_clut224;
extern const struct linux_logo logo_dec_clut224;
extern const struct linux_logo logo_mac_clut224;
extern const struct linux_logo logo_parisc_clut224;
(四)修改 defconfig(内核配置启用)
编辑 defconfig,启用 Logo 功能(删除冗余声音配置):
OK3568-linux-source/arch/arm64/configs/OK3568-C-linux_defconfig
diff --git a/arch/arm64/configs/OK3568-C-linux_defconfig b/arch/arm64/configs/OK3568-C-linux_defconfig
index 97d46ceff..d5af9f21d 100644
--- a/arch/arm64/configs/OK3568-C-linux_defconfig
+++ b/arch/arm64/configs/OK3568-C-linux_defconfig
@@ -590,3 +590,18 @@ CONFIG_RCU_CPU_STALL_TIMEOUT=60
CONFIG_FUNCTION_TRACER=y
CONFIG_BLK_DEV_IO_TRACE=y
CONFIG_LKDTM=y
+# Console display driver support
+CONFIG_FONT_8x8=n
+CONFIG_VGA_CONSOLE=y
+CONFIG_DUMMY_CONSOLE=y
+CONFIG_DUMMY_CONSOLE_COLUMNS=80
+CONFIG_DUMMY_CONSOLE_ROWS=25
+CONFIG_FRAMEBUFFER_CONSOLE=y
+CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY=y
+# CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set
+# CONFIG_FRAMEBUFFER_CONSOLE_DEFERRED_TAKEOVER is not set
+CONFIG_LOGO=y
+CONFIG_LOGO_LINUX_MONO=n
+CONFIG_LOGO_LINUX_VGA16=n
+CONFIG_LOGO_LINUX_CLUT224=y
| 配置项 | 说明 |
| CONFIG_FRAMEBUFFER_CONSOLE=y | 启用帧缓冲控制台 |
| CONFIG_LOGO=y | 启用Logo显示功能 |
| CONFIG_LOGO_LINUX_CLUT224=y | 启用224色Linux Logo |
| CONFIG_LOGO_LINUX_MONO=n | 禁用单色Logo |
| CONFIG_LOGO_LINUX_VGA16=n | 禁用VGA16色Logo |
(五)修改 fbcon.c(动画播放逻辑)
编辑 fbcon.c,添加帧循环播放和延时逻辑:
OK3568-linux-source/kernel/drivers/video/fbdev/core/fbcon.c
diff --git a/drivers/video/fbdev/core/fbcon.c b/drivers/video/fbdev/core/fbcon.c
index bf7959fdf..2607ac9cb 100644
--- a/drivers/video/fbdev/core/fbcon.c
+++ b/drivers/video/fbdev/core/fbcon.c
@@ -569,6 +569,7 @@ static void fbcon_prepare_logo(struct vc_data *vc, struct fb_info *info,
if (fb_get_color_depth(&info->var, &info->fix) == 1)
erase &= ~0x400;
logo_height = fb_prepare_logo(info, ops->rotate);
+ logo_height += (info->var.yres / 2) - (logo_height / 2); // 垂直居中
logo_lines = DIV_ROUND_UP(logo_height, vc->vc_font.height);
q = (unsigned short *) (vc->vc_origin +
vc->vc_size_row * rows);
@@ -2037,6 +2038,8 @@ static int fbcon_resize(struct vc_data *vc, unsigned int width,
return 0;
+extern int fb_get_logo(struct fb_info *info, int num);
static int fbcon_switch(struct vc_data *vc)
struct fb_info *info, *old_info = NULL;
@@ -2158,7 +2161,14 @@ static int fbcon_switch(struct vc_data *vc)
logo_shown = fg_console;
/* This is protected above by initmem_freed */
- fb_show_logo(info, ops->rotate);
+ // fb_show_logo(info, ops->rotate);
+#if 1
+ int i;
+ for (i = 0; i < 25; i++) { // 循环播放 25 帧 + fb_get_logo(info, i); + fb_show_logo(info, ops->rotate);
+ msleep(50); // 每帧延时 50ms,可调整动画速度
+#endif
update_region(vc,
vc->vc_origin + vc->vc_size_row * vc->vc_top,
vc->vc_size_row * (vc->vc_bottom - vc->vc_top));
可通过修改msleep(50)的值来调整动画播放速度,数值越小动画越快,建议范围 30-100ms。
(六)修改 fbmem.c(Logo 位置与函数导出)
编辑 fbmem.c,修正 Logo 显示位置并导出 fb_get_logo 函数:
OK3568-linux-source/kernel/drivers/video/fbdev/core/fbmem.c
diff --git a/drivers/video/fbdev/core/fbmem.c b/drivers/video/fbdev/core/fbmem.c
index 7a70e7b80..63cfad4c0 100644
--- a/drivers/video/fbdev/core/fbmem.c
+++ b/drivers/video/fbdev/core/fbmem.c
@@ -509,10 +509,10 @@ static int fb_show_logo_line(struct fb_info *info, int rotate,
fb_set_logo(info, logo, logo_new, fb_logo.depth);
- image.dx = 0;
- image.dy = y;
image.width = logo->width;
image.height = logo->height;
+ image.dx = (info->var.xres / 2) - (logo->width / 2); // 水平居中
+ image.dy = (info->var.yres / 2) - (logo->height / 2); // 垂直居中
if (rotate) {
logo_rotate = kmalloc_array(logo->width, logo->height,
@@ -681,12 +681,25 @@ int fb_show_logo(struct fb_info *info, int rotate)
return y;
+int fb_get_logo(struct fb_info *info, int num)
+ int depth = fb_get_color_depth(&info->var, &info->fix);
+ depth |= num << 16; + fb_logo.logo = fb_find_logo(depth); + if (!fb_logo.logo) { + return -1; + } + return 0; +} #else int fb_prepare_logo(struct fb_info *info, int rotate) { return 0; } int fb_show_logo(struct fb_info *info, int rotate) { return 0; } +int fb_get_logo(struct fb_info *info, int num) { return 0; } #endif /* CONFIG_LOGO */ EXPORT_SYMBOL(fb_prepare_logo); EXPORT_SYMBOL(fb_show_logo); +EXPORT_SYMBOL(fb_get_logo);
(七)修改 bitblit.c(隐藏光标)
编辑 bitblit.c,禁用光标显示避免影响动画效果:
OK3568-linux-source/kernel/drivers/video/fbdev/core/bitblit.c
diff --git a/drivers/video/fbdev/core/bitblit.c b/drivers/video/fbdev/core/bitblit.c
index 436365efa..e8e874653 100644
--- a/drivers/video/fbdev/core/bitblit.c
+++ b/drivers/video/fbdev/core/bitblit.c
@@ -373,7 +373,8 @@ static void bit_cursor(struct vc_data *vc, struct fb_info *info, int mode,
if (info->fbops->fb_cursor)
err = info->fbops->fb_cursor(info, &cursor);
- if (err)
+ // if (err) // 禁用软光标
+ if (0)
soft_cursor(info, &cursor);
ops->cursor_reset = 0;
四、编译验证
完成所有修改后,执行内核编译命令,生成新的镜像文件并烧录到 RK3568 开发板,启动开发板即可看到居中播放的 Logo 动画(25 帧循环,每帧延时 50ms)。
详细编译方法请参考飞凌嵌入式提供的《OK3568编译手册》。
