【飞凌嵌入式 OK3399-C 开发板试用体验】(安装RabbitMQ消息队列服务】
作者:fcb5511
提供两种消息队列服务安装方式:
2、erl # 查看relang语言版本,成功执行则说明relang安装成功
在rk3399浏览器中输入localhost:15672,登陆用户名和密码分别为”guest”、”guest”。
局域网内计算机浏览器输入192.168.1.109:15672,用户名和密码分别为”admin”、”admin”
import pika import threading import time import signal import os class Producer(object): def __init__(self, host='127.0.0.1', port=5672, user='admin', passwd='admin', exchange='test_exchange', routing_key='test_key', exchange_type= 'fanout', exhcange_durable=False, exchange_autodelete=True ): self.host=host self.port=port self.user=user self.passwd=passwd self.exchange=exchange self.routing_key=routing_key self.exchange_type=exchange_type self.exhcange_durable=exhcange_durable self.exchange_autodelete=exchange_autodelete self.connection=None self.channel=None def CreateConnection(self): try: self.credentials=pika.PlainCredentials(self.user, self.passwd) self.connection = pika.BlockingConnection(pika.ConnectionParameters(host = self.host, port = self.port, virtual_host = '/', credentials=self.credentials)) self.channel = self.connection.channel() self.channel.exchange_declare(exchange_type=self.exchange_type, exchange = self.exchange, durable = self.exhcange_durable, auto_delete=self.exchange_autodelete) except Exception as e: print("occurring an exception when the producer executing the function 'CreateConnection()':", e) def PublisMessage(self, Message): try: self.channel.basic_publish(exchange=self.exchange, routing_key=self.routing_key, properties=pika.BasicProperties(delivery_mode = 2), body=Message) except Exception as e: print("An exception occurred when publishing message:", e)
amqconsumer.py程序:
import pika import time class Consumer(object): def __init__(self, host='127.0.0.1', port=5672, user='admin', passwd='admin', queue='test_queue', exchange='test_exchange', routing_key='test_key', queue_exclusive=False, queue_durable=False, queue_autodelete=True, exchange_type= 'fanout', exhcange_durable=False, exchange_autodelete=True ): self.host=host self.port=port self.user=user self.passwd=passwd self.queue=queue self.exchange=exchange self.routing_key=routing_key self.queue_exclusive=queue_exclusive self.queue_durable=queue_durable self.queue_autodelete=queue_autodelete self.exchange_type=exchange_type self.exhcange_durable=exhcange_durable self.exchange_autodelete=exchange_autodelete self.connection=None self.channel=None def CreateConnection(self): try: self.credentials=pika.PlainCredentials(self.user, self.passwd) self.connection = pika.BlockingConnection(pika.ConnectionParameters(host = self.host, port = self.port, virtual_host = '/', credentials=self.credentials)) self.channel = self.connection.channel() self.channel.queue_declare(queue=self.queue, durable=self.queue_durable, exclusive=self.queue_exclusive, auto_delete=self.queue_autodelete) self.channel.exchange_declare(exchange_type=self.exchange_type, exchange = self.exchange, durable = self.exhcange_durable, auto_delete=self.exchange_autodelete) self.channel.queue_bind(queue = self.queue, exchange = self.exchange, routing_key = self.routing_key) self.channel.basic_consume(on_message_callback = self.on_response, auto_ack=True, queue=self.queue) except Exception as e: print("occurring an exception when the consumer RecvData:", e) def on_response(self, ch, method, props, body): #print(" [%s] Received %r" % (time.time(), body)) print(time.strftime('%H:%M:%S',time.localtime(time.time()))+': Get Message from '+self.host + ':'+body.decode()) def ProcessConsumeEventBlock(self): try: self.channel.start_consuming() except Exception as e: print('An exception occurred when executing consuming, the exception is:',e) def ProcessConsumeEventNoneBlock(self): try: self.connection.process_data_events() except Exception as e: print('An exception occurred when executing consuming, the exception is:',e)
main.py程序:
import pika import time import threading from amqconsumer import Consumer from amqproducer import Producer class ManageMent: def __init__(self): self.producer = Producer(host='localhost',user='guest',passwd='guest') self.consumer = Consumer(host='localhost',user='guest',passwd='guest') def CreateSever(self): self.consumer.CreateConnection() self.producer.CreateConnection() def ProducerRun(self): while True: self.producer.PublisMessage('this message is used for testing RabbitMQ') time.sleep(0.3) def ConsumerRun(self): self.consumer.ProcessConsumeEventBlock() def Run1(self): while True: self.producer.PublisMessage('this message is used for test RabbitMQ') self.consumer.ProcessConsumeEventNoneBlock() time.sleep(1) def Run(self): self.Consumer_thread=threading.Thread(target=self.ConsumerRun) self.Producer_thread=threading.Thread(target=self.ProducerRun) self.Consumer_thread.start() self.Producer_thread.start() if __name__ == '__main__': manage=ManageMent() manage.CreateSever() manage.Run()
最终运行效果如图
此贴为基础功能,下次将mq数据与qt界面结合,实现动态的界面。
FET3399-C核心板
了解详情 -
OK3399-C开发板
