【飞凌嵌入式 OK3399-C+开发板试用体验】本地编译内核源码&DHT11驱动编译
作者:donatello1996
飞凌厂商提供的Linux源码资料压缩包实际上是多合一源码,除了最常用的内核源码以外,还有诸多额外内容比如交叉编译链,Linux烧录工具(卡刷+线刷),生成系统镜像img的脚本,uboot源码,应用程序代码等诸多内容,这些不同内容面向不同层次的开发者,比如开发应用层的只看应用程序代码即可,开发驱动的只看内核源码和交叉编译链即可,开发uboot的只看uboot源码即可,产品部门相关的只需要会用工具即可。内核源码为主目录的kernel文件夹,交叉编译链为主目录的prebuilt文件夹,平时如果执行厂商提供的build_ubuntu.sh脚本,实际上不只是编译内核和驱动(boot.img,**.ko),还有生成必须要的分区镜像如recovery.img,userdata.img等:
1.mount /dev/sda /mnt 2.cd /mnt
然后是在板子上安装64位aarch编译工具,通常Ubuntu系统都会自带的:
apt install aarch64-linux-gnu-gcc
那么就可以直接在板上进行本地内核编译了:
1.make clean 2.make rockchip_linux_defconfig 3.make
1.apt install libssl-dev 2.apt install libssl1.0.0= 1.0.2g-1ubuntu4.16
1.cd /mnt/RTL8192EU 2.make clean 3.make
#define QUECTEL_VENDOR_ID 0x2c7c
然后是EC20/EC25的公用产品ID 0x0125:
#define QUECTEL_PRODUCT_EC25 0x0125
{ USB_DEVICE(0x2C7C, 0x0125) }, /* Quectel EC25 */
继续在此文件drivers/usb/serial/option.c文件中找到option_probe 函数,在此函数里面添加如下内容:
if (dev_desc->idVendor == cpu_to_le16(0x05c6) &&
dev_desc->idProduct == cpu_to_le16(0x9003) &&
iface_desc->bInte**ceNumber >= 4)
return -ENODEV;
dev_desc->idProduct == cpu_to_le16(0x9215) &&
return -ENODEV;
if (dev_desc->idVendor == cpu_to_le16(0x2c7c) &&
return -ENODEV;
static struct usb_serial_driver option_1port_device = {
.driver = {
.owner = THIS_MODULE,
.name = "option1",
.description = "GSM modem (1-port)",
.id_table = option_ids,
.num_ports = 1,
.probe = option_probe,
.open = usb_wwan_open,
.close = usb_wwan_close,
.dtr_rts = usb_wwan_dtr_rts,
.write = usb_wwan_write,
.write_room = usb_wwan_write_room,
.chars_in_buffer = usb_wwan_chars_in_buffer,
.tiocmget = usb_wwan_tiocmget,
.tiocmset = usb_wwan_tiocmset,
.ioctl = usb_wwan_ioctl,
.attach = option_attach,
.release = option_release,
.port_probe = usb_wwan_port_probe,
.port_remove = usb_wwan_port_remove,
.read_int_callback = option_instat_callback,
#ifdef CONFIG_PM
.suspend = usb_wwan_suspend,
.resume = usb_wwan_resume,
.reset_resume = usb_wwan_resume,
#endif
static struct urb *usb_wwan_setup_urb(struct usb_serial_port *port,
int endpoint,
int dir, void *ctx, char *buf, int len,
void (*callback) (struct urb *))
struct usb_serial *serial = port->serial;
struct urb *urb;
urb = usb_alloc_urb(0, GFP_KERNEL); /* No ISO */
if (!urb)
return NULL;
usb_fill_bulk_urb(urb, serial->dev,
usb_sndbulkpipe(serial->dev, endpoint) | dir,
buf, len, callback, ctx);
if (dir == USB_DIR_OUT) {
struct usb_device_descriptor *desc = &serial->dev->descriptor;
if (desc->idVendor == cpu_to_le16(0x05C6) && desc->idProduct ==
cpu_to_le16(0x9090))
urb->transfer_flags |= URB_ZERO_PACKET;
if (desc->idVendor == cpu_to_le16(0x05C6) && desc->idProduct == cpu_to_le16(0x9003))
if (desc->idVendor == cpu_to_le16(0x05C6) && desc->idProduct == cpu_to_le16(0x9215))
if (desc->idVendor == cpu_to_le16(0x2C7C))
return urb;
static struct file_operations mygpio69_fops = {
.read = MYGPIO69_read,
.write = MYGPIO69_write,
.open = MYGPIO69_open,
.release = MYGPIO69_close,
与设备树的mygpio69节点对应:
static const struct of_device_id of_mygpio69_match[] =
{ .compatible = "mygpio69", },
添加节点之后就可以在驱动代码里面进行GPIO写电平操作了,复写MYGPIO69_write函数,超级简单:
static int mygpio69_gpio = 69;
//GPIO号
#define MYGPIO69_LOW gpio_set_value(mygpio69_gpio, 0)
#define MYGPIO69_HIGH gpio_set_value(mygpio69_gpio, 1)
static ssize_t MYGPIO69_write(struct file *file,const char __user *buf,
size_t nbytes, loff_t *ppos)
if(buf[0]==1)
MYGPIO69_HIGH;
else if(buf[0]==0)
MYGPIO69_LOW;
当然了,要正常调用这些函数操作GPIO,是要先初始化GPIO的:
if (gpio_request(mygpio69_gpio, "mygpio69_gpio"))
printk("gpio %d request failed!\n", mygpio69_gpio);
gpio_free(mygpio69_gpio);
return -ENODEV;
else
printk("gpio %d request success!\n", mygpio69_gpio);
make生成ko文件之后,就会在/dev目录下生成mygpio69设备文件,可以在应用层代码直接操作:
int main ()
int fd ;
unsigned char val[4],value;
fd = open ( "/dev/mygpio69" , O_RDWR) ;
if ( fd == -1 )
perror ( "open /dev/mygpio69 error\n" ) ;
exit ( -1 ) ;
printf ( "open /dev/mygpio69 successfully\n" ) ;
while (1)
value=0;
write(fd,&value,1);
sleep(1);
value=1;
write(fd,&value,1);
sleep(1);
close ( fd ) ;
static u8 DHT11_Read_Data(u16 *temp,u16 *humi)
u8 buf[5];
u8 i;
DHT11_Rst();
if(DHT11_Check()==0)
for(i=0;i<5;i++)//读取40位数据
buf[i]=DHT11_Read_Byte();
if((buf[0]+buf[1]+buf[2]+buf[3])==buf[4])
*humi=buf[0]<<8|buf[1];
*temp=buf[2]<<8|buf[3];
printk("buf=%d,%d,%d,%d,%d\n",buf[0],buf[1],buf[2],buf[3],buf[4]);
}else return 1;
return 0;
static ssize_t DHT11_read(struct file *file, char __user *buf,
printk("--------------%s--------------\n",__FUNCTION__);
dht11_data Last_dht11_data;
if(DHT11_Read_Data(&Last_dht11_data.temp,&Last_dht11_data.hum) == 0);//读取温湿度值
if (raw_copy_to_user(buf,&Last_dht11_data,sizeof(Last_dht11_data)) )
return EFAULT ;
static struct file_operations dht11_fops = {
.read = DHT11_read,
.open = DHT11_open,
.release = DHT11_close,
static const struct of_device_id of_dht11_match[] = {
{ .compatible = "dht11", },
MODULE_DEVICE_TABLE(of, of_dht11_match);
static struct platform_driver dht11_driver = {
.probe = dht11_probe,
.remove = dht11_remove,
.shutdown = dht11_shutdown,
.driver = {
.name = "dht11_driver",
.of_match_table = of_dht11_match,
insmod dht11_drv.ko
做个简单的小实验看下DHT11能否正常读取温度:
typedef struct DHT11_SENSOR_DATA
unsigned short temp;//温度
unsigned short hum;//湿度
}dht11_data;
int main ( void )
int fd ;
int retval ;
dht11_data Curdht11_data;
fd = open ( "/dev/dht11" , O_RDONLY) ;
if ( fd == -1 )
perror ( "open dht11 error\n" ) ;
exit ( -1 ) ;
printf ( "open /dev/dht11 successfully\n" ) ;
sleep ( 2 ) ;
while ( 1 )
sleep ( 1 ) ;
retval = read ( fd , &Curdht11_data , sizeof(Curdht11_data) );
if ( retval == -1 )
printf ( "read dht11 error" ) ;
exit ( -1 ) ;
if(Curdht11_data.temp != 0xffff)
printf ( "Temperature:%d.%d C,Humidity:%d.%d %%RH\n",
Curdht11_data.temp>>8,
Curdht11_data.temp&0xff,
Curdht11_data.hum>>8,
Curdht11_data.hum&0xff ) ;
close ( fd ) ;
FET3399-C核心板
OK3399-C开发板
